HI AGAIN SORRY FOR DELAY heres an update everything works fine if i take the hdmi that comes out off my denon avr arc in to arc on the tv no blackouts on projector do you think this 2 Way 4K UHD HDMI Splitter with EDID, HDCP 2.2That almost sounds like a current output problem at the sink (display) side. Try my suggestion about ruling out the AVR first. Do you use ARC, and if so, is ARC/CEC disabled on all of your HDMI connected devices, not just the BraviaSync on the tv?
All you can do is try. 4k HDR typically doesn't like any "breaks" in the HDMI chain and this is especially true with an active cable at your length.HI AGAIN SORRY FOR DELAY heres an update everything works fine if i take the hdmi that comes out off my denon avr arc in to arc on the tv no blackouts on projector do you think this 2 Way 4K UHD HDMI Splitter with EDID, HDCP 2.2
could fix the problem
4k or 4k HDR? HDMI 2.0 option sets or HDMI 2.1 option sets. A processor or receiver doesn't really count as a "break" in the HDMI chain. What we are referring to are wall plates, extenders, adapters, couplers (as in daisy chaining). At 1m for the "8" cable, there are no distance issues so almost any cable would do depending on whether you whether you are pushing the 4k HDR HDMI 2.0 options or the 4k HDR HDMI 2.1 options.I have 2 15m 4K cables connecting my dvd and processor to the TV and haven’t had any issues in nearly 2 years.
Also recently bought a 1m 8k for sky to processor.
bought the ezcoo hdmi splitter 30 quid everything works fine now edid seems been the problemAll you can do is try. 4k HDR typically doesn't like any "breaks" in the HDMI chain and this is especially true with an active cable at your length.
