Hello
I've had a Samsung 40H6670 for around 6-7 years now and it's been perfect. If I recall, it was one of the best rated 40 inch LED sets in my price range at the time I bought it (here's one of the reviews from the time! an old review).
I've been looking at the next-gen games consoles that are coming out soon and after a long absence from the video games scene I fancy getting one! But to get the most out of it, I reckon a new TV is in order!
As I've been more than pleased with my current set, I've had a look at the Samsung range, initially the 43Q60/65T and the 43TU7100 (possibly superseded by the TU8000?). I've seen these available for £549 and £349 respectively. I understand the first is QLED and the second is 'Crystal UHD'. The reviews for the Q60T do not sound impressive and suggest that the larger sizes in that range are much better - but I only have room for a 43 inch set maximum, so am I better off sticking to the cheaper UHD range and getting a mid-top one of those, or going for the low-end QLED? Or should I look at a different brand altogether?
The TV is mainly used for Netflix, Now TV, Amazon Prime and (hopefully!) some next-gen gaming.
Any advice appreciated! Thank you!
