Erdzean Sybico
Is the Acer AN515-54 laptop able to connect to VR headsets specifically Oculus Rift S or the HTC Vive? The laptop has an I5-8300H CPU, 8 GB RAM, and has an Nvidia GEFORCE GTX 1650 GPU but it does not have a display port that the Rift S needs to connect to, it does have a type-c connector but I'm not sure if its for that purpose. I'm not sure if the HDMI is connected to the GPU which the Vive says I need in their setup video.
Link to the setup video timestamp 4:30
Link to the specs
Images of the ports
Link to the specs
Nitro 5 AN515-54
Intel® Core™ i7 (i7 - 9750H, 2.60 GHz, 12 MB) - 39.6 cm (15.6") LED - 16:9 Full HD - LCD - ComfyView - NVIDIA® GeForce® GTX 1660Ti Up to 6 GB - 16 GB DDR4 SDRAM - No - Colour Obsidian Black - Weight (Approximate) 2.50 kg - Maximum Battery Run Time 8 Hour
www.acer.com
