Colin151
- Joined
- Sep 7, 2007
- Messages
- 1,523
- Reaction score
- 130
- Points
- 373
- Age
- 51
- Location
- Kensington Olympia, London
I think the answer is no, but does anyone know if it Is possible to adjust the relative level of the 0.1 LFE channel level separately with Yamaha receivers? That is the very low bass track, I’ve had in the past a 3067, 3040, 3050 and 3060 and not found a way to do it. I don’t think it’s there in any of the settings. It’s strange as most other receiver brands I’ve tried have the ability to adjust it, - usually under a setting called LFE or LFE level. You can adjust it from 0 into minus numbers with the Pioneer SC LX59 for example. With the Yamahas it’s stuck at max volume (0).
With the Yamahas there is a subwoofer trim setting but this isn’t the same thing as adjusting the relative LFE level.
It’s a very strange oversight by Yamaha. Their much older receivers had this setting (I remember my old DSP-A1 did)
