b1g1an
- Joined
- Aug 15, 2005
- Messages
- 1,389
- Reaction score
- 499
- Points
- 275
I'm guessing you come from the time when you put the big CRT telly in the corner so it didn't fill the lounge. Unfortunately, that position just doesn't work if you have an interest in home cinema and there comes a time when you just have to swallow it and completely replan the lounge to get the TV in the middle of a wall. Loads of us have been there and although it can be a major upheaval you'll never look back once it's done.
If you then followed @gibbsy's advice re positioning you should find the kit you already have would work much better but worth doing the upgrades you've been looking at at the same time so you can just sit back and enjoy it for a long time.
