D
Deleted member 24354
As this might be a good option for those that are retrofitting an old alarm system.
I am actually replacing an entire wired system with an Ajax alarm system using their MultiTransmitter which takes all of my existing wired inputs and converts them to wireless inputs that the Ajax alarm can read. So I will keep all of my Pyronix KX10DP detectors (which I know work well with my cats) plus additional Ajax wireless sensors.
I also have embeded door contacts that are invisible that I did not want to replace with surface mounted contacts.
This will give me a hybrid wired / wireless alarm with all of the advanced capabilities of an Ajax system without having to replace 8 sensors and door contacts. I also have Ajax MotionCams in the system for visual verification
Additionally I have my interlinked Firex Mains / Battery smoke/heat alarms, wired via a Firex relay base, that will form a zone on my Ajax system for smoke/fire detection as well as Ajax FireProtect smoke detectors
The MultiTransmitter is due next week and I will be posting a full review here.
