I'm looking for smart plugs that provide monitoring (there are plenty) but at a low level, say every 15 minutes or less, and that can either send their data to a cloud, a server or the data can be collected via an app for export to a spreadsheet.
I have all the home power usage monitoring I need at the PV/Grid/Battery storage levels, what I want to drill down to is the per device usage patterns, and the plugs I gave found just don't give either the detail or the means to export the data to use actively.
efergy seems to have an old plug (pre 2015) with a more granular data capture, but it's not a smart device that works with Alexa etc, and every one elses app seems to have captive data and low resolution.
Can't be rocket science!
