rjames1701
Established Member
Apologies if posted in the wrong section but it was the only Apple forum I could find.
Equipment. Panasonic gz1500 oled. Denon avr-4400. Panasonic UB820 Blu-ray.
All cabling goes through AVR.
If I connect the Apple 4K *direct* to the tv then I can successfully enable Dolby vision.
Blu ray plays Dolby atmos and vision through avr to the TV.
If I plug the cable from the blu ray into the Apple, same avr Input as blu ray, then half the tv turns green when selecting “Try Dolby Vision” and i have to settle for 4K SDR.
I don’t think it’s the avr as I can pass a DV signal from the Blu ray to TV via avr. I’ve proven it’s not a cable issue as I use the same uhd cable as blu ray
The only thing I can think of is that the avr does not like the Apple TV in some way.
Can anyone offer any suggestions to what I might try next?
Thank you
Rich
Thank you
Rich
