Quantcast
Arcam AVR390 / AVR550 / AVR850 including Dirac Live®
Steve356
Ah, I knew this for movies but I thought that mp3/flac were not "mapped" 2.0/2.1. Thanks!
They should be mapped as Stereo, which will play as either 2.0 or 2.1 depending on your preferred configuration. At least that's how it works in my system when I listen to iTunes via my Apple TV box.
Sgt Hartman
Thanks for the tips Steve! In any case I suppose that another solution is to unplug the speaker that I don't want utilize... :laugh:
inferno_red
I just got a svs SB16 sub. Should you make any peq adjustments prior to Dirac (phase/polarity/eq etc)? Or should you not bother and just let Dirac do it’s thing?
pepelugil
Sorry for this little off topic, but I’ve bought an Umik-1 and most of you use them, I’d be pleased if you could clear up a doubt I have with mine: I’ve downloaded calibration file from MiniDSP web and I see it starts with a -44.783 value for 10.054 Hz that raises proportionally to a value of -10.065 at 13.698Hz, then for 13.869 Hz it raises abruptly to -0,9164 and stays most of the time between -1 and +1 until 8630.343 Hz when again drops to -10.510 and then progressively quips falling down until a value of -79.665 is reached at 20016.816 Hz. If this value of almost -80 normal or do I have to worry?
But what bothers me more is that between 22.193 Hz and 70.132 Hz the values abruptly change from -1 values to values between +10 and +12 in this range, does this mean that my Umik-1 is not good enough for these frequencies and that’s why these corrections are needed?
Sgt Hartman
Hello guys, is anybody there with Arendal speakers and an Arcam AVR? I'd like to know how to properly make the setup with Dirac Live, thanks!
007L2Kill
Sounds very wrong, tell us your mics serial number and I take a look.
How’s it measure via REW?
Sgt Hartman
I have the the arendals and avr850. They sound fantastic.
I personally have the 550, do you set up the AVR in a particular way before lunching the Dirac software (e.g. Speaker Types, Levels, etc.) or do you let it do all the job autonomously?
inferno_red
I level match the speaker and put the distance in. Dirac is independent of these but I do it anyway so that I can compare before and after. You will need to make sure the speakers are assigned e.g sub present etc before launching Dirac.
Dirac will eq to a curve. It doesn’t set the Cross over or speaker type. You need to do this. Good starting point would be small speakers ( let the sub take the strain) and 80hz cross over (although you don’t say what arendals you have so this value could change?).
There are loads of pages in this thread with useful tips and the Dirac website has a manual that will talk you through it...best of luck
fatboy frank
Try down loading it again, as the results i get for your mic serial number are very different
fatboy frank
fatboy frank
Your link doesn;t show values anywhere near +10.
The link i linked to looks fine to me, although i'm no expert on the subject, as @RBZ5416 say's tthere's nothing like the values you said you were getting. Try down loading the Cal file again, maybe you had a dodgy download!
Sgt Hartman
My setup will be 2x 1723 Towers, 1x 1723 S Central, 4x 1723 S Bookshelf, 1x Subwoofer 2. So basically I should insert anyway distances, speaker types (only subwoofer Large?), etc.? Crossover frequency still at 80 Hz?
fatboy frank
If i was you, i'd do a basic setup ie set your speaker distances, speakers small, sub present and initial crossover of 80Hz, do a level match using either the internal test tones, or preferably using an external source and calibration disc and SPL meter. Get used to the natural sound of your new speakers and get some hours on them before you bother doing a Dirac calibration.
fatboy frank
I'm doing exactly that myself while testing out some ATC front speakers with my AVR850, which I've had for 3 years.
Which ATC's ? Nice speakers whichever ones you've got, i am considering adding some ATC SCM 20-2 actives for stereo.
Steve356
ATC SCM 19, so the passive consumer version of the ones you are looking at. I'm very impressed so far, but it is early days as I only picked them up this morning.
fatboy frank
Sgt Hartman
So, basically you are suggesting a bit of "warm-up" free from any calibration... It might be an idea also because I suppose I should listen to them in different configurations, towers can be both sealed and ported, even if I suppose sealed might better (in theory). Ok, thanks for the tip.
felty99
I upgraded to a pair of ATC SCM40A’s recently and they are superb with the AV860. Fantastic bass and control, almost make my Velodyne sub redundant
Similar threads
Trending threads
Latest News
MQA expands global partnerships for high end experience
  • By Andy Bassett
  • Published
Samsung 2020 TV app lineup upgraded
  • By Andy Bassett
  • Published
Film festivals move online: We Are One starts 29th May
  • By Andy Bassett
  • Published
Bafta 2020 TV Awards to proceed behind closed doors
  • By Andy Bassett
  • Published
Tidal brings Dolby Atmos Music to home cinema setups
  • By Andy Bassett
  • Published
