What about the cable from the Arcam to the TV?Thanks for all responses
Cables from the Sony UHD player and Sky Q into the Arcam are (short length) Premium certified (the same as I was using into the Denon AVR).
Which output from the Arcam to the TV?
Can you just temporarily unplug the premium certified cable from the Sky box to the Arcam and use that to connect your Arcam to your TV. So, you have premium certified from UHD player to Arcam and premium certified from Arcam to TV.Same as it was with the Denon AVR: latest spec optical fibre HDMI, and works perfectly when used to connect the Sony UHD player and Sky Q to the TV directly,
Some fibre optic HDMI's are directional, don't suppose you've connected it the wrong way round?Same as it was with the Denon AVR: latest spec optical fibre HDMI, and works perfectly when used to connect the Sony UHD player and Sky Q to the TV directly,
Do you still have problems with the UHD player if connected that way?
Have you tried UHD player - premium certified - Arcam - premium certified - TV ?Short answer is yes, there are problems with both the Sony UHD player and SkyQ going via the Arcam (using premium cables) - connected directly to the TV they work fine. ARC from the TV (Netflix / Disney+ etc.) into the Arcam (for sound) also works fine.
Makes me wonder whether there is problem with the HDMI pass-through handing in the Arcam?
Was the unit a brand new unit or customer return/demonstrator, also what version version of Firmware is it on and have you carried out a factory reset?Short answer is yes, there are problems with both the Sony UHD player and SkyQ going via the Arcam (using premium cables) - connected directly to the TV they work fine. ARC from the TV (Netflix / Disney+ etc.) into the Arcam (for sound) also works fine.
I know you say it works okay if connected direct to TV and it worked okay with your previous AVR but I am afraid HDMI connectivity does not use that logic.
Brand new. Latest firmware downloaded onto USB, installed and factory reset done. Checked latest version is shown on the display.Was the unit a brand new unit or customer return/demonstrator, also what version version of Firmware is it on and have you carried out a factory reset?
Sounds like you have faulty unit as HDMI pass through should work fine.Short answer is yes, there are problems with both the Sony UHD player and SkyQ going via the Arcam (using premium cables) - connected directly to the TV they work fine. ARC from the TV (Netflix / Disney+ etc.) into the Arcam (for sound) also works fine.
There seems to be some confusion around your use of "pass-through". Are we talking about with the amp on or in standby?
Must admit that i'm a bit confused with some of the things you've said, HDMI Pass-through refers to the passing through of a HDMI Input when the Arcam is in standby, this will be the last used HDMI input if you have enabled it in the menu?Thanks again for all the suggestions.
A step forward but not there yet: active optical fibre 2m cable now connecting the Sony UHD player to the BD input on the 850. The UHD player menu now appears on the screen in 4k (if forced to in the player output menu) and clear of any sparkles! However when a 4k Dolby Vision disc (1917 - magnificent film) loads the 850 will only pass through at 1080p, despite the player settings to 4k/HDR/Dolby Vision. And there is no sound.
So, my hunch is that the Arcam is particularly demanding of a very strong HDMI input signal (active fibre cable, normal premium certified just doesn't do it), and there is also a fault with its HDMI pass-through and audio extraction. Will call the dealer tomorrow.
I previously had an AV9 with my P7 before moving to an AVR390 (via a Marantz AVR). I saw the review on ASR for the 390 and he said that the level doesn't increase above 75 on the master volume. The P7 has 29dB gain though, so it may be less of an issue for us; I can hit some pretty high levels in my room with MK MPS300 for LCR that are 4.5 metres from the MLP.It’s gonna be time replace my Trusty AV9 soon and have been looking at a 550 as a processor to use with my P7 but I hear rumblings that the pre out voltages have been limited for use in this purpose ?
anyone have any knowledge of this and the drawbacks ?
Apart from the fibre optic HDMI cable, what premium certified cables do you have to hand?Thanks again for all the suggestions.
I'm leaning towards a settings issue in the player, and not configured properly in the Arcam.Apart from the fibre optic HDMI cable, what premium certified cables do you have to hand?
Hello guys,
Sorry if it sound like a silly question but I was wondering, as trigger cables, from AVR550 to 2 amplifiers, can I use also stereo types or must be mono only?
