Thanks for your reply, i read you could use bubbleUPNP app onnphone for spotify tidal quobuz so was wonderingnid there was a work around like thatIt is only a UPNP streamer with no way of loading apps so no.
I believe the link you quoted refers to the BubbleUPnP Android app's old & no longer available Amazon Cloud Drive function, which allowied playback of your own mp3 music files uploaded to the now defunct Amazon Music Storage service.Amazon Music via UPnP/DLNA to stream - so it goes
Songs from Amazon Music you can stream via DLNA/UPnP. Here we will show you how you exactly need to do.technical-tips.com
The BubbleUPnP Android app uses the officially provided APIs for its Qobuz and TIDAL functions, so is actually true support for those online music streaming services rather than a workaround.Thanks for your reply, i read you could use bubbleUPNP app onnphone for spotify tidal quobuz so was wonderingnid there was a work around like that
Thank you so much. Very informative. I think i might look for a Arcam Rplay for my streaming needs for the moment. Seems to suport amazon music out of the boxThe BubbleUPnP Android app uses the officially provided APIs for its Qobuz and TIDAL functions, so is actually true support for those online music streaming services rather than a workaround.
BubbleUPnP doesn't actually support Spotify, so the possible workaround you could be referring to is its less well known Audio Cast function. This should allow you to send to a UPnP/DLNA streamer a capture of the phone's own audio being produced by another app such as the official Spotify app, so may also work with the official Amazon Music app.
However, BubbleUPnP's Audio Cast function is only available if you have previously installed & configured the Android Xposed Framework, which is only available to rooted Android devices. Also, don't expect the audio capture to be bit perfect, so a poorer quality sound than the original being produced by the music streaming app may possibly be sent to the UPnP/DLNA streamer.
Thanks this is the article i saw , but couldnt see a way to link amazon hd, i emailed bubble directly and they said amazon dont allow 3rd party applications to access music library so they no longer support itAmazon.co.uk: Amazon Music HD FAQs: Digital Music
Online shopping for Amazon Music HD FAQs from a great selection at Digital Music Store.www.amazon.co.uk
