Hi Nayfne thank you for the prompt response back - the AV is the Sony strndn1080 - 55inch LG oled tv.Set your blu ray/4k player to bitstream audio, turn secondary audio off...what A/V receiver are you using?
Yes - I have the Sony ultra HF blu-ray UBp-x800And do you have a blu ray/4k player?
I can say that when watching title on Netflix which is Atmos I do get Atmos appearing on the Sony AV - does this mean that I should be getting Atmos sound from the speakers? I wanted to test to be sure ? ThanksAnd do.you have any blu ray discs/4k discs which have Dolby Atmos soundtracks?
If so, stick one on, select Atmos, if you have to, on the films main menu, check your display on the Sony Receiver, should show up as Atmos.
Sounds spot on to me..just don't be expecting overwhelming activity from the Elacs..they should add to the immersion but shouldn't be active all the time..this does depend on what content you are watching, and full fat Atmos on discs will sound better than the streaming alternatives.I can say that when watching title on Netflix which is Atmos I do get Atmos appearing on the Sony AV - does this mean that I should be getting Atmos sound from the speakers? I wanted to test to be sure ? Thanks
Thank you very muchSounds spot on to me..just don't be expecting overwhelming activity from the Elacs..they should add to the immersion but shouldn't be active all the time..this does depend on what content you are watching, and full fat Atmos on discs will sound better than the streaming alternatives.
Hi, how can I check ?Your avr display should also show what speakers are active including the elac atmos speakers.
Download these test files gives you a good example of atmosHi
I have a Atmos set up but want to check if I do have Atmos from the elac upfiring speakers
how can I test please ?
please can anyone help
Thank youDownload these test files gives you a good example of atmos
Dolby Atmos - Official Site
Take your music and entertainment to the next level with Dolby Atmos, a revolutionary spatial audio technology for the most immersive sound experience.www.dolby.com
Thank you.If Atmos is showing up on the display then the receiver is getting an Atmos feed. However, don't expect your ceiling to come alive with sound. It's more subtle than that and upfiring speakers will lift the front soundstage and place object based sounds at a ceiling level when the soundtrack has them. Don't go listening for it everytime you turn the receiver on, you may very well be disappointed, especially if the film is somewhat devoid of Atmos effects.
The best way to tell is let yourself get use to the speakers being in operation. Then turn those speakers off in the receiver or disconnect them. Then you will notice that the overall audio loses that height element.
