BigA1
Hey guys,
Just wanted to post some pics of my almost finished AV cabinet.
I used 3 IKEA BESTA TV units to form a credenza to house the AV equipment and for the 75" Q90R to sit on.
The units fit almost made to measure in my alcove and eventually will be adorned with a 15mm x 4m x .70M oak worktop so that the entire depth of the alcove is sealed hiding all the wires and dust that usually settles behind AV equipment/cabinets.
I've installed a 6 Gang Horizontal 13amp Switched Power Distribution Unit inside the left cabinet and Black Brush Cable Management bar for the power and other cables.
In the right cabinet I have 2 more Black Brush Cable Management bars for 2 levels of equipment.
I have installed an ARCTIC P12 PWM PST 120 mm Case Fan in each side to vent out any hot air.
The fans are connected to a DC 12V 24V 48V 2 Way Cooling PWM 4 Wire Fan Temperature Controller with thermostats which is powered using a DC 5v To DC 9v or 12v Adjustable Step-up Voltage Regulator Converter with Switch DC Connector that is plugged into the One Connect Box USB port.
And it all seems to be working swimmingly...
Happy to answer any questions or recieve any comments etc.
Al.
Al.
