Quantcast
Barbecues are bloody brilliant Part 3
Fergal82
Recently bought some big k restaurant grade charcoal from Ocado - been doing this for a while now. I normally get the 15kg lump wood but they had run out and sent me some big k brickettes which are shaped like long tubes in an octagon profile. Can I get these bloody things to light easily? Having a nightmare, they take forever. Anyone else tried these and sussed our how to light them without going through a pack of firefighters and taking an hour? If not, after previously wholeheartedly recommending big k restaurant grade, I would recommend staying away from these! once lit they do last a good while though....
Are you using a chimney starter?
invisiblekid
Trouble is those octagon sticks are pretty big so you won't get many in a chimney. But some is better than nothing and then stack up the rest once you put them on the BBQ. They are widely used in restaurants with gas starters as they do last but more importantly have pretty even heating.
I'm sure they are buggers to start, you'd need a heavy duty gas torch as the best method.
Fergal82
I use a chimney starter to light mine and it works a treat
dracthelad
Yes chimney starter and half a bag of fire lighters in bunches of threes. Will be a case of experimentation as I have 3 boxes of them, Lol! They just don’t catch quickly enough and I don’t have a gas blow torch like my uncle in SA for his braai!
dracthelad
any tips? My chimney starter was lit before 6pm and took over an hour before I could start grilling....
Fergal82
Where are you standing the chimney starter, sounds like you’re not getting enough air flow underneath. I use 3 of those natural fire lighters and it’s usually raging after 10mins
dracthelad
Usually stand it on the grate in the Weber, might have to go back to free standing... you using this specific charcoal? I’ve used all sorts but never had this much grief....
dracthelad
For a long cook it‘ll be amazing as it’s absolutely raging now and will do so for a good while. With the vents closed they’ll last forever. I think I’ll have to revisit my lighting regime!
Fergal82
Yep and cook it on my Weber as well.
Time to try some different fire lighters?
dracthelad
Hmmm may have to. So much for eco fire lighters!
Cheers for the input guys :thumbsup: this thread goes a bit quiet this time of year!
hyperfish
When I ran out of firefighters I tried my electric weed burner to start the chimney and have been using it ever since. Starts a charcoal chimney in 3 minutes.
invisiblekid
It's a pity this combo is either out of stock in the UK and when it is available, pretty expensive.
Jimmer
New bbq time, in the midst of the build. Looking forward to a six hour rib cook this fine November Sunday.
Dony
I use the brown paper padding that comes in Amazon boxes to get my chimney starter going. Haven't need to use firelighters at all.
aerodynamic18
my kj is currently in a shipping container whilst our extension is built :( sad times but will be worth it in the end as I will be able to build a bbq after the build is done
IronGiant
Nice, I quite often buy from them.
invisiblekid
Is that a butt? Could just be the angle but looks like belly. Good breed though,
But they have a good range of meat though. Burgers and bangers look good.
JimmyMac
It’s a butt, just a huge fat cap on it!
So this thing has cooked far quicker than expected. Need it for about 4pm today and expected it to be done around midday so I could wrap and hold it till nearer time
however it’s pretty much ready now. If I foil rap and keep it in the oven at around 80C will it survive about 6 hours do we think?
lowmans100
Wrap in foil/cling film, then wrap in a couple of towels and put in a cooler box. It will hold temperature for hours.
If you don;t have a cooler box wrap in a few towels.
When you shred and serve, if it's too cool then put portions in the microwave and serve with a warmed up bbq sauce.
Jimmer
iGrill 2 for £35.99
SilkyStefan
I bought the rotisserie attachment for my Weber 57cm in the Black Friday sale at riversidegardencentre (good place for Weber stuff). I've only cooked a practice turkey on it in the build up to Christmas but it was a lot of fun and an interesting new way to cook. The photos don't really do it justice.
Trending threads
Latest News
BenQ launches new Home Cinema and Gaming projectors
  • By Andy Bassett
  • Published
Acorn TV streaming service to launch in UK
  • By Andy Bassett
  • Published
LG UK 2020 TV rollout and prices revealed
  • By Andy Bassett
  • Published
TV shipment forecasts slashed for Q2 2020
  • By Andy Bassett
  • Published
Samsung Display to quit LCD production
  • By Andy Bassett
  • Published
