Hi, thanks for the replyfloor or bookshelf?
any colour or finish preference?
which country are you in?
type of music?
how much space can you accommodate?
do you prefer new or dont mind used?
Eithermatt or gloss black?
Cheersmission lx2
bronze 2
fyne audio f301
wharfedale 11.1
if your amp is good enough:
mission qx1
concept 20
I have ordered the Q Acoustics 3020i instead of the Mission LX2's, thanks for your help.also the acoustic energy ae100 are £199 in walnut if you can live with it. in black they're £229.
I'd go with mission lx2 to be on the safe side aa im not familiar with your amp. the missions should fill the size of your room.. the q acoustics might be a bit bass light in your room size.
No I don't suffer from OCD lol, It's because I'm running the cable under the carpet profile to the wall.it shouldn't matter. if you have OCD then have them the same.
32 feet is a long way away.
Cheers Steve,When you say £200, you are really saying in the £100/pr to £200/pr range, and we can do that.
But, if you can push up into the £200 to £300/pr range, we can recommend some pretty impressive speakers. You don't even have to go to the full £300, just above £200.
In a more compact speaker with modest bass, but good sound, then -
Q Acoustic Q-3020i (5.25") - £168/pr -
Q Acoustics Q 3020i Bookshelf Speakers (Pair), English Walnut at AV.com
Q Acoustics Q 3020i Bookshelf Speakers (Pair), English Walnut at AV.comwww.audiovisualonline.co.uk
Just one man's opinion.
Steve/bluewizard
Good Choice.Cheers Steve,
That's the one's I ordered today in black, coming on Monday from Audio Visual Online for £168.
