brooklynmuse
Hi folks,
Trying to take advantage of Cyber Monday deals -
I'm looking to get an integrated amp in the $500 range (though ideally more like $350) and it seems 50–60-watts per channel in 8Ω will be best.
range that will make these beauties sing. I mostly listen to Jazz/Acoustic/Afrocuban/Classical
Also appreciate your recommendation for any subs you think would sound best:
The room is about 10.6 ' x 18 ' (including 4 windows and approx 13 feet ceiling)
- source ranges from spotify to vinyl
- I'm looking to be able to add on devices like a cd player and cassette player, tuner
- I'd like a remote or phone remote ability.
- bluetooth for computer
- love ability to tinker with EQ
Placement in in a nook against exposed brick in an open floor plan living room/kitchen.
Measurements of entire space is 22x17.
Many thanks!
Michelle
B&W 606
Audio Technica AT- LP60
Many thanks!
Michelle
B&W 606
