Just had a few hours blast.
First thing I noticed was the graphics, very disappointing. Just doesn't look very good at all considering its on a 'next gen' console.
Anyway gameplay. The special abilities are interesting, and definitely have a use in the game. Seen a lot of players using different ones, so it's good that everyone isn't just going for same one. Personally I have found some decent, and some very good.
The jumping in the game I think works well, it feels a little more basic compared to advanced warfare, I'm not sure if that's a step back or a good thing as I think gun play is more of an factor now. The maps at times can be a bit annoying for jumping though, some roofs and surfaces you think you'd be able to get onto you can't, which just feels a bit silly.
Players die very quickly. Its not often you get a chance to fire back if you get shot from the back or side. Guns seem decent balanced, used a few good guns mainly from lmgs and assault rifles. Shotgun could be popular too.
Kill streaks seem decent, the bomber (second streak by default) is maybe a bit OP as seen a lot of kills by them, although myself have only got a double with it. There's hasn't been loads and loads of steaks about, I think players die a lot and quickly so streaks can be tough.
Overall though it seems good I have to say, it doesn't feel massively different from other cods or anything, and it is similar to advanced warfare but I do think it is more focused on gunplay now. Which is a good thing.
An hours session turned into 3 hours. So that's always a good thing. I'll keep at it though for few days before pre ordering.
