Devaucas
Hi, I am planning to buy 5.1 speaker package to go with Denon X2600h, please suggest good 5.1 speaker package or should i choose 5 speakers and subwoofer seperate, Appreciate your inputs, Thanks....
even better to have 3 centres from rsI have to say that I am very impressed with my budget speaker setup which I use with a 2600.
Although discontinued the Eclipse range from Tannoy is fab for those of limited means.
Right now 4 Eclipse 1s and an Eclipse Centre can be yours for £147 - 2 pairs of 1s open box from Peter Tyson and the centre from Richer Sounds.
I find the BK subs on ebay to be excellent value; my Xxls400 was less than £400 and is sublime.
True for films as panning would be seamless.even better to have 3 centres from rs
Thanks Liam.....Sub in that size room is a must, your not going to get any sort of bass without one. I’ve owned both the wharfadale and q acoustics 7000i and 3000i systems. The subwoofers that come with the packages are all pretty useless, especially the wharfedale one. Out of the three the 3000 series offers imo great performance for the money. The other two small satellite systems don’t offer much grunt for movies at all. Stay clear from Bose.
I’d go for 5.1 3000 series and a Bk sub, maybe xls400.
If you look for second hand this could be had for under 600! Hope this helps.
