rulocal
- Joined
- Jan 4, 2003
- Messages
- 4,946
- Reaction score
- 4,409
- Points
- 1,678
So do Stackry open your existing package and then repackage it? Or, if you only have 1 package, do they just put a new label on that and send it?
I don’t think I have ever only had 1 package but I think they give you the option to repack as shipping is done on volumetric weight which means smaller packages are cheaper. If you have bought just discs I cant imagine it would make much difference but it sort of depends where you have ordered from and how it was packed. You also have the option for them to remove the paperwork, which is advisable.
