I'm looking at a pair of these as a birthday present, or the Sony M3's. Does anyone know how many, and which type of buds these ship with now. I believe they only came with one set when they were launched, but are now shipped with several pairs. Thanks
Out of interest do you have the Comply Sport, Isolation or Comfort tips? I've been told Comfort don't fit in the case but the large Isolation do. The Comply site says the Comfort medium are smaller than the Isolation large though.I bought mine recently. It came with three different size silicon tips and one pair of medium foam tips.
In the end after trial and error over the last few weeks I've settled on the Cambridge Audio large foam tips as my favourite, with Comply T600 medium as a runner up.
Strange, when I search the comply site for Melomania they only show up Sport, Isolation and Comfort in size T600. What are the regular ones called? I can't find them listed on comply or Amazon. T600 is just the size, the model is Sport, Isolation or Comfort I believe. It is a bit confusing though.No. The only Comply tips I found in stock were regular T600. My ears tend to narrow these a little at the tip which negatively affects sound - removing some highs. Which is why I now prefer the official large foam tips, which don't do this.
@ £2.80 per bud someone is making a killing on these.My apologies, it seems the "Isolation" ones are the item I bought. I didn't know they were named that.
Yeah, bit pricey but very comfortable compared to silicone and the CA foam which is a lot harder.@ £2.80 per bud someone is making a killing on these.
My birthday is next week so have to decide whether to pull the trigger on these, or the Sonys'. I think with these you have to accept a bit o f fiddling about to get the fit right, but probably worth the effort. However one of the earlier post on this thread rated the Sonys' over these CA's.Yeah, bit pricey but very comfortable compared to silicone and the CA foam which is a lot harder.
Have to say I've favoured these all along, it was just that comment that sewed the seeds of doubt I think I will go for these though, as the extended battery life and their smaller size make them prefferable over the Sonys. Also as you have pointed out they are quite a bit cheaper. Decision made! Thanks for your inputI've not heard the Sony but once I got the right fit these sound great. Think these are quite a bit cheaper than the Sony too. They're also smaller.
