senu
Pls repost this in the general forum . Ill remove it shortlyPanasonic nv-gs50 video camera
always in a pose mode, when you want to record
gives you a black screen.Does anyone know why?
Davinci Resolve 14. It is free for a fully functioning lite version. It is what the big boys use in movies and tv. Has the best defacto standard color grading built in. Insane motion tracking. Only thing is it is built to edit editing formats. So you will want to transcode your mp4 and h.264 files to much larger editing formats such as dnxhr on windows or Linux or prores if you are on a Mac.Can someone suggest a good Video Editing Software for Windows 10 ,64 bit ?
One that does not cost an arm and a leg and is straight forward to use ?
Something that can be viewed on you Tube ? thanks ...
It took me 1/2 a day and some youtubes to learn to do basic editing good enough for Youtube. I am not sure what the file restrictions were, in fact I found almost the opposite, it was the least restrictive of all of the free packages as it was one of the only packages that had no problems with AVCHD files.it will take a long time to get to grips with.
No it just leans against the stabilizer upright and misses the handle completely when the stabilizer isn't fitted. That particular side handle mount (made by Hama) is very well made and folds flat, so it fits in a small gadget bag. I don't think that they make that model anymore ? Incidentally you mentioned a screen sunshield the other day. I have had one for ages as I certainly need it in Spain where we spend half the year.With that vertical hand grip does it foul the flip out screen on that same side I wonder.
