eddiem74
Established Member
So I got some alcove cabinets built in and my AV receiver (Denon 3100W) fits perfectly sitting flat without any cables plugged in the rear. When I add cables in order to close the door the cables are pressed as tight as you want them to be against the back panel. So it does work I am just not that comfortable with it.
Is there any issue or risk if I was to stand the receiver on its side/edge as this will give me the room needed? I know the casing is ventilated on the top and sides but can it be done.
The alternative option is cutting some of the back out of the cabinet into the small void left behind it to gain a few mm but as everything is in place now, would like to avoid that.
