PhillyG76
Established Member
Hi, I have a Honda Civic mk8 2009, and will be having a Pioneer sph-250dab fitted at end of month. I felt the sound from the Honda had poor bass, and people say change head unit first and you will notice difference but don’t know how much. Was planning getting some Focal ones but they’re quite expensive and wondering if it’s overkill if the stereo itself improves the sound. So thinking of lowering budget to around £150, does anyone have any recommendations? If there’s some that are a huge amount better for spending maybe an extra £20 then I’ll not refuse spending a bit more. The Hertz range seem good value. But are the cheaper Focal ones any good? Did really like the flax cone ones, and if can be sure it’s worth spending the extra then won’t say no. But would I be happy with more bass spending around the £150 range.? Many thanks for suggestions and advice.
