So I have the AMD Ryzen 5 3600 processor, built the pc yesterday (2nd pc build). Everything with my first pc build runs good and no issues, even in AAA games at high resolution. The problem is with the second one I built yesterday, with the same-ish parts, even in windows 10 on idle (only ryzen master or HWmonitor open) the cpu temperatures keep spiking up and then down Example: it goes from 50 to 65 degrees, and even up to 87 degrees (with nothing open except temperature monitors). For reference, the first pc has stayed at 40-50 degrees when using normally, even when gaming it does not get as high as the 2nd pc's cpu.
Any advice appreciated.
