Ali Raza
Try changing the audyssey from reference to flat
Its already set to flat with dynamic eq off.
With such small speakers you need Reference. The X6500 is most likely outperforming your speakers.Its already set to flat with dynamic eq off.
I've just done a YPAO on my Yamaha and it determined my fronts were large. If I now manually set them to small, isn't this going to through off all the frequency adjustments YPAO has implemented?
How do I set them to small, then run YPAO without them being changed back to large?
You'd need to set the crossover to a frequency that complies with the capabilities of your least capable speakers. It is a global setting and will apply to all speakers designated as SMALL. Speakers designated LARGE are not subject to the crossover filter.
I'd still suggest you try the setup with all your speakers designated small with a crossover setting of 120Hz though rather than setting the front speakers as LARGE.
I am not an expert, but my understanding is that you should set your Sub's crossover at Max and volume at half. Let the receiver control the crossover. After running your calibration, you may need to go back and adjust the "LEVEL" of the sub to suit your taste and room conditions
Hello,
I have dual Rel 212se, and use it for movies only. I am also using a Marantz SR6012.
Questions I have:
- I only use LFE/.1 correct, not low level?
- what should my dial settings be on the back of the subs? Do these settings get bypassed since I am using LFE? (except LFE volume)
- Hi/Low setting - ?
- LFE - I understand this setting
- Crossover - ?
