It works fine with the latest firmware V4.31. The only issue remaining is that you have to set your speakers to large and the crossover to 200Hz during calibration, after that you can set whatever speaker size and crossover you like.A real shame Arcam didn’t implement Dirac properly - the only thing that would stop me buying. These prices are great.
Are you on about combining an AVR with an integrated amp, if so the A49 is your best option as it has class G amps like AVR850 and also has AV bypass mode which the A39 does not have, previous A38 did have this.Arcam has announced several new gears. Maybe new AVR will come this year?
Maybe time to jump on the wagon....Any thought how AVR850 would compare with A39 or A49?
Depends on your surround speakers & listening levels. Several reports of the 390 being a bit weedy & shutting down. Obviously offloading the front pair would help.Yes. The two options could be (1) AVR850 or (2) AVR390+A49.
Not sure I'd get much stress relief in there!You could always pop in the shop next door if you are stressed out after spending loads of money in Musicraft
heheNot sure I'd get much stress relief in there!
The NAD T 758 V3 and T 777 V3 are worth consideringInteresting development! How does that workaround avoid the issue from occurring? Does it mean the main speakers don’t get corrected in the sub 200Hz region as that’s no good either - any chance you can show me some REW plots?
I can stump up for the 390, but I am not sure, all things considered it would be better for me than my Marantz SR7011 for movies as I get on well with the Audyssey stuff and Dynamic EQ is great. Sure SQ for music would be better but the configurability of Audyssey and the 2ch settings pinned to the CD output on the Marantz are really good.
Might wait and save for 850 once end of line prices like these are more common...that’s how I got an AV9 + P7 many moons ago at about half price.
Is the fix/workaround documented by Arcam?
Thanks for the info.
dealers had enough of having to prop up such flawed products & ditching them altogether?
That answers that question then!he was not impressed with the company and never want to deal with them again.
