Alexxxx
Hi, I am currently in the process of building a dedicated cinema room and was wondering if I could get some advice.
The room would be as close to completely black as it could be, very small window with blinds and thick black curtains, so vitually pitch black.
The room is 3mx4m with 2.6m ceilings, which will accommodate 100 inch projector screen. Minimal ambient lighting will be present in a form of 2 very dimm ligthts attached to the wall or 2 small light strips, not 100% decided on that one.
I was considering painting the walls and ceiling dark grey or even potentially clad the walls in black/dark material. If the walls are clad with fabric, what do I do with the ceiling? What material would you recommend? Would painting the walls dark grey suffice and how dark is dark enough (don't want to paint the ceiling completely black).
Any advice would be greatly appreciated.
EDIT 03.02.2020:
After careful deliberation, here are my top fabric (my personal opinion).
1 Micro velvet £6.49/m
#BST Fabrics w=112cm
Product Page
#2 Stretch velvet £7.64 for 4m<, £6.50 for 10m<, £6 for 25m<
melebinltd w=145cm
Velvet Fabric, Luxury High Quality Craft Dressmaking Stretch Material 57" | eBay
#3 Micro velvet £8.99/m
Cheap Fabrics w=112cm
Micro Velvet
#3 Micro Velvet Black MVEL22 BK £7.99/m
TiaKnight w=112cm
#5 SILK/VISCOSE VELVET BLACK (DEVORE) £30.43/m 3m<, £25.35/m 1-m<, £20.6/m >10m.
Whaleys - Bradford w=unknown
#6 Cotton Velvet Fabric (EUF285-X321-E26B121) £7.99/m, £7.67 for 15m<, £7.43 for 25m<
EU Fabrics w=112cm
EDIT 03.02.2020:
Product Page
melebinltd w=145cm
Micro Velvet
TiaKnight w=112cm
Micro Velvet Velour Fabric Luxuriously Soft Velvet- Black MVEL22 BK
Indulge into our luxuriously soft and sumptuous velvet. Our micro velour is non-stretch, has an excellent drape, and is perfect for interior designs & décor! Sold by the metre. Fabric use, excellent material for interior designs, acoustic panels, stereo speaker covers, cushion covers, curtains...
www.tiaknightfabrics.co.uk
Silk/Viscose Velvet Black Devore - Silk Fabric | Whaleys Bradford
A light weight Velvet suitable for scarves, with a short pile. Fabric is prepared for dyeing and/or printing. Approx 195gsm.
www.whaleys-bradford.ltd.uk
EU Fabrics w=112cm
-- As an eBay Associate, AVForums earns from qualifying purchases --
