Soepy
Hi all. Is it possible to connect a power amp to this please. I seen in the amp assign that you can but can't see on the amp where to connect an input? TIA
Zone B is stereo only therefore the Zone would have a full downmixed signal and cannot be used as part of the surround set up.The 2600 supports assigning 2 pairs of front speakers using the Zone2 as a second pair of fronts, which are selectable to use either A or B. Surely if you used Zone2 as Front pair B and selected them, this would allow pre-outs for a selected B-pair of fronts. This would limit the system to 5.1 but would allow using a power amp for the front 2 speakers.
Its a question rather than assertion as i don't have a 2600 to play with.
