Quantcast
Denon AVR-X2200W/AVR-X3200W Owners Thread
simonlewis
As i have just recently purchased the Denon AVR-X2200W reciever in the last few day's, i thought i would start an owners thread. :smashin:
dante01
You'd be hard pushed to find the receiver for less than its suggested retail price so early after its launch. Denon only supply Denon authorised retailers who are obliged to advertise products at the prices Denon allow them to. You may get a better deal by contacting the retailers yourself as opposed to looking for cheaper prices online? Make them an offer, you never know your luck :)
Seen one for £498 if that is of any help? :D
raduv1
99% sure this will be the model I choose this year. It fills my needs for the UHD BD standard and has Atmos/DTS X that I would like to explore, I'm hoping and expecting that the uhd BD will have ATMOS/DTS X as standard going foward ( time will tell ).
I currently run the Onkyo 609 and although I see the Denon as an update to take advantage of said formats I do have a question on upgrade.
Audyssey, will the 2200 be a significant upgrade to the Audyssey calibration from my 609 ? This runs the multi EQ XT I believe but is it more of an update than upgrade ?
Hoping to run a 5.1.2 set up with.
Bowers and Wilkins M1 surrounds.
SVS SB2000 sub ( maybe the new XTZ range )
Cambridge Audio minx for Atmos.
I'm 99% sure this amp will the one so you fellas can fill out the 1% of doubt :).
dante01
UHD BD will not include DTS:X or Atmos as standard. There's no reason why the studios would adopt either wholesale just because of the launch of UHD BD. In fact, you'd be hard pushed to see much support being given fo UHD BD full stop. You don't need UHD BD to include the new object orientated formats so fail to see what the new disc based delivery system would have to do with the inclusion of these formats? The audio will have been mixed and authored in the exact same way has it would have been for HD Blu-ray and HD Blu-ray will still out sell UHD BD because there isn't going to be a huge uptake of the new UHD disc based system by consumers.
raduv1
My thinking was (I did put a disclaimer of sorts ) that a new format such as UHD BD would adopt the highest standards in audio quality (bells and whistles ) and I expect any atmos BD will also be avaliable to UHD BD. I'm no expert but I would expect this new standard to adopt the latest in sound and picture. It was a side note to my main question though so no worries :).
raduv1
Maybe I should of gone with just this.
Same price point as when I purchased the 609 , update/upgrade for me Audyssey wise ?.
mrmoo
Here's an odd one. Plugged in an old Samsung Blu-ray player BDP1500 to try the Atmos encoded film Gravity. No sound, except on the front HDMI port. Tried all the rear inputs and no sound, tested them all with an xbox and a HTPC and they all work fine. Looked at every setting I can think of and can't find any reason the front port would be any different to the rear. It decodes Atmos brilliantly, sounds amazing but it's not very practical plugged in the front. Any ideas? Handshake issue?
dante01
Atmos encoded cntent has exhibited some strange behaviour on older players as a result of the seamless branching used during the authoring of the discs.
http://www.audioholics.com/news/dolby-atmos-old-blu-ray-players
Your issue doesn't appear to exhibit the symptoms associated with seamless branching though and there's no explanation as to why you can access the content via front HDMI input on your receiver? Maybe the player is detecting something its EDID is uncomfortable with in conjunction with the receiver other HDMI inputs and therefore prevented fro outputting the audio?
Every input has its own configurations on your receiver. I'd look at the configurations associated with the front HDMI input and compare them to how you've configured the other HDMI inputs in order to ascertain whether or not there are differences that explain the receiver's behaviour?
simonlewis
I just thought i would bump this thread. :)
golden phoenix
how does this compare with the marantz 6010? still cant find much info or reviews on the marantz thought they'd start appearing by now since they are released next month
spectra7045
received my x2200 today and have started to set it up.
One possibly naive question should I be able to view a second television connected to the second hdmi output at the same time as one connected to hdmi 1. I recognise it would not come from a different input but am getting no signal on my second set
dante01
Yes you can output the same video signal via both HDMI outputs simultaneously. The HDMI video output setting within the HDMI settings of the receiver should be set to AUTO by default. This setting would result in both outputs outputting a signal. Also set the RESOLUTION setting in the OUTPUT SETTINGS to AUTO so that the receiver outputs the video compatible with both TVs. The lesser capable TV will determine the resolution being output to both sets. A point worth mentioning is that you will not be able to passthrough audio without bypassing the receiver's own handling of the audio. The purpose of the two outputs isn't to allow for an additional HDMI zone, but to facilitate the connection of both a PJ and a TV to the receiver for use in conjunction with it within the same room.
What are the video capabilities of both your TVs? How long is the HDMI cable going to the TV not displaying the signal and is it a high speed HDMI cable?
raduv1
Does RS do this AVR as I've been unable to find it on the site ?
spectra7045
Thank you for that.
I think it was the length of the HDMI cable as hdmi 2 was ok when I attached it to a shorter cable.
The cable was a good one but was across 3 rooms.
Have gone back to splitting my sky cable and all seems to be fine.
I had not really thought you would get no audio from the second connector anyway so whole plan was a non starter.
So far very impressed with the amp the sound clarity compared to my old (almost antique) yamaha is amazing.
alitech
Just a quick note to thank dante01 for introducing me to the avrx2200w. I just picked one up today from RS that I reserved last week. I am just setting it up right know so may come back with questions.
alitech
Oh yes, I know there are a few of you still wanting to get your hands on one and looking for discounts as well. I picked mine up for £429 form RS. I bought a Samsung 75incher from them about a month ago so I leaned on them and got the price down to £429 with a managers discount. Give it a try. Will upload an image of the receipt when I get on a pc
alitech
I will be setting this up with an HTPC, PS3, Sky box, Virgin tivo and a Samsung 75JU7000 TV. I will bring all these devices together with a logitech harmony one ultimate remote. Will come back with experiences with all said devices and the harmony remote.
simonlewis
I am currently watching Zero Dark Thirty on channel 4 on my amp it's saying dolby digital + dolby stereo (at the same time) i've noticed this before, is this normal ?
raduv1
Good to know as RS are always keen and willing to deal . Didn't have one in store for me to have a demo last week but hopefully this week they will have some in and will phone me for a demo.
spectra7045
I got mine from creative audio for £429 with next day delivery excellent service and very friendly helpfull sales guy.
Tried RS but the best price they could give me as a member of their VIP club was £480.
LoneGunmanUK
I'm seriously considering getting this amp. How are you finding it so far in terms of sound and ease of use? I'm a fan of Yamaha amps and would like to know how it compares.
gord1
I just purchased this amp. My Sony 550 packed in after approx 5/6 yrs and I checked out review after review contemplating just upgrading to the Sony 1050 but kept looking at the Denon 2100 and then the 2200 as I thought to myself if you are going to upgrade your Panasonic 55 inch tv in the next year [its about 6/7 years old and has never failed me] then buy a receiver that will do the job if upgrading to a 4k tv.
I bought the 2200 from Creative Audio on Monday was delivered today Tuesday. Very helpful staff cant fault them. Well recommended.
The 2200 arrived around 4 pm and by 4.30 pm I had connected the speaker wires and started the calibration. After the first test the amp found fault with my centre speaker and after I realised my wiring was wrong started the calibration again. It takes you through 8 tests moving the mic around the seating area, very easy. Then it told me to start connecting the usual stuff that I have which is sky box, vu+ sat receiver, sony blu ray player, ac ryan media player and samsung smart blu ray player. These were all connected by HDMI. After that I went into the menu and just changed the source menu name from e.g. cable to sky making life a bit easier.
Then I tested every device through the box and all is great. No further modification needed.
Great sound, clear, crisp, nice sound from the subwoofer far superior than the old sony.
My set up is 2 front speakers, 2 surround and 1 sub woofer. 3.2.1.
Delighted with this receiver and the sound quality is superb.
alitech
Glad you are happy with the amp and the service from creative audio gord1.
If you want the atmos speakers check out this site
Onkyo SKH410 Haut-parleurs compatibles Dolby Atmos 100 W: Amazon.fr: Audio & HiFi
This is where I bought mine from great price and good delivery
Hey buddy. What's your experience with these any good? Where have you placed them and where are they pointing? In the audessey calibration, it does not have an option for additional front atmos speakers.
Also, if you don't have an atmos soundtrack, do they work as standard satellites?
Similar threads
Trending threads
Latest News
AVForums Podcast: 27th January 2020
  • By Phil Hinton
  • Published
Raidho TD Series loudspeakers arrive in UK
  • By Andy Bassett
  • Published
Nokia 2.3 phone available in UK for £100
  • By Andy Bassett
  • Published
Sky to launch Documentary and Nature channels
  • By Andy Bassett
  • Published
StormAudio to launch MK2 home cinema range at ISE 2020
  • By Andy Bassett
  • Published
