Quantcast
Denon AVR-X2500H Owners Thread
MattyCB
Hi All
Now the proud owner of one of these beauties but having some teething problems around Atmos playback. The unit shows the source as Atmos but even with Atmos selected as mode the Dolby Front Left and Right Speakers in the Info screen are not showing as engaged (not solid blue). Has anyone else had this, should they only be lit at the exact moment an Atmos effect is played on that channel?
Matt
peter-d-w
I suspect there is a problem with your configuration. I would advise you to rerun the setup and check your connections.
MattyCB
I suspect there is a problem with your configuration. I would advise you to rerun the setup and check your connections.[/QUOTE
Thanks I've rerun, not sure if it is a bug but still there if I play Atmos the Info button shows no active Dolby speakers (empty rather than solid blue) if I then go into audyssey and restore settings it comes back for a while then disappears again without me changing anything. Will call Denon as has me doubting the setup even though confident it's setup right.
peter-d-w
Check your wiring to the speakers for loose connections and make sure that the firmware in the AVR is up to date. Don't rely on the built in check routine, my 8500 reported that it was up to date when it wasn't because it wouldn't connect to the internet. I had to download up to date firmware and install from USB. Once the new firmware was installed in connected to the Internet with no problems.
flashf1
Hi, can anyone tell me if this has the GUI overlay menus/volume bar etc on a 4K 60p HDR input?
flashf1
I can now confirm that it does a GUI overlay (including set up menu) up to 4K 30fps.
On my apple TV's menu screen (4K 60FPS), the volume bar works, and the options (mini menu) work, but if full set up menu is selected screen will go black before displaying setup menu
addyeddy
Are people happy with the sound quality of this receiver? My Onkyo TX - NR646 has just died. This Denon has a similar set of features including a phono input I've never had a Denon before, but have only heard good things about them, and wonder if this will be equal to or better than the Onkyo.
paulr2006
Assuming the X2500 follows on like the 2400 & 2300 before it you should find it’s far more musical than the Onkyo. I had an Onkyo 656 then an X2300 which sounded much nicer, less harsh on music but great on movies too. I would also consider an X2400 (last years model) which can be had for around £150 less with almost the same spec.
Ste7en
I'm trying to figure out the differences between the AVRX2400 and the AVRX2500H but failing badly. My brother is after a new AV amp and I'd suggested the AVRX2500H (at his price limit) but I stared to wonder if he would be better off with the AVRX2400.
He runs a 5.1 system but really wants to route everything via his new amp with HDMI. He has an old amp and he streams a lot these days so he can't get 5.1 (no HDMI inputs). Oh, and he listens to Spotify a lot.
Any suggestions would be greatly appreciated.
paulr2006
Personally I would go with the X2400, to all intents they are almost identical, happens every year, the Amp. basically stays the same with just a few (usually not needed) additions. When I bought my X2300 it was originally £499 but as the X2400 came in it dropped to circa £300. The X2400 is only cheaper due to the X2500 appearing on the scene.
paulr2006
addyeddy
Just bought the 2500h as it has a phono input, I don't think the 2400 has.
addyeddy
Wow is all I can say, new owner and delighted. Bought it to replace an Onkyo 646 that just died on me overnight(no sound all of a sudden), and thought I was happy with the sound of that, but this just blows it out of the water. Far superior soundstage to my ears, and just a nicer overall sound.The user interface is great too, and setup was a breeze. Really pleased so far and would recommend to others.
addyeddy
Help required please! Although happy with the performance on films, have been playing some music via dvd audio, sacd, blu ray audio and ordinary CD, and it sounds like it's behind a veil, nowhere near as clear as my old Onkyo. My main beef is lack of top end, is this a Denon characteristic? Is there a setting I can magically adjust to get more clarity? Any help or advice appreciated.
gibbsy
Most of the Denons, my X6200 included, is pretty poor for music, especially stereo. Best to use pure direct. Unfortunately the 2500 has no pre-outs and bringing a stereo amp into the mix is out of the question.
addyeddy
Have tried it on pure, and it's incredibly quiet. Have found that I have to have this receiver on 40-50 whereas my Onkyo was usually on 20-25. I'm kind of thinking l might have to return this if I'm not going to get decent music reproduction, was hoping for a decent all rounder.
gibbsy
If you want a better solution for music as well as film then you would be better off looking at a Marantz. As for relating the volume it's always better to use the dB scale rather than the absolute scale.
++ Jase ++
I've just got a X2500H and quite pleased with it.
I have a question regarding Video output setting. By default it is set to auto but there are options for Game, Movie and Bypass.
As I use this for gaming on a Panasonic OLED, I was wondering what the best option is as I do not want to be adding any input lag/latency to it. Last night I choose bypass but is it OK to leave on Auto?
flashf1
If you want a GUI overlay and volume bar, leave on auto. But if you dont need volume bar, and dont mind screen switching to black if you go into the menus, choose bypass, this will mean no processing at all. 99% of the time there is no difference (as long as youre doing no scaling), however on Blade Runner 2049 there are some scenes that will display posterization on auto, but play perfectly with bypass.
++ Jase ++
Many thanks, for the consoles I have opted for bypass just incase :)
monkeyharris78
Hi, just got this amp and got a question on the hdmi outputs.
I have a samsung tv on hdmi 1 for during the day and a Benq w2000 projecter on hdmi 2 for watching films etc. It takes quite a bit of messing around to get the amp to fire up with the projector without the tv coming on. Is there a simple way to just switch between the outputs? Or is there a certain order in which to switch things on?
gibbsy
You will need to turn off the CEC control on the TV so that it does not turn on when firing up the Denon. Just use the pre-sets on the remote, 1 for the TV, 2 for the PJ. Press either of those numbers and the Denon will fire up with the correct input already selected.
monkeyharris78
Thanks will give that a go
leamspaceman
Hi All
Matt
I've got a Denon 2500 and an Oppo 203.
I've just popped in my first Atmos encoded UHD Blu... 'The Equalizer.'
I also have FLD or FRD that aren't engaged on the display despite the amp auto switching to Atmos and I'm sure I can hear sound from the Atmos speakers.
Here's the display:
Here's a shot when I'm watching Freesat and have 'faux' Atmos enabled. All speakers are engaged:
I have played a Netflix stream with Dolby Atmos but it's from the TV's internal app and sound is being sent by ARC to the amp... so pressing the 'info' button doesn't show anything so you can't see which speakers are engaged?
@MattyCB ... did you solve this?
EDIT:
Just tried another Atmos disc and the speakers are showing as engaged:
MattyCB
@leamspaceman you are getting exactly what I got - an intermittent fault showing the Atmos speakers not engaged when they are. I found that if I go into the Audyssey menu and reload defaults (even though nothing has changed) it springs into life. I have reported all of this to Denon who have said they are unable to recreate using my photos and steps ( I have Oppo 203 too BTW, but it happens with any source). Perhaps if you have the time to report it too they might sort it, for now I'm living with what is a minor annoyance.
Similar threads
Trending threads
Latest News
Philips OLED burn-in solution is 95 percent effective
  • By Andy Bassett
  • Published
Philips TV’s with HDMI 2.1 and Dolby Vision IQ due in time
  • By Andy Bassett
  • Published
Sonos clarifies product update and recycling position
  • By Andy Bassett
  • Published
Philips 4th Gen P5 processor adds AI for more realistic images
  • By Andy Bassett
  • Published
LG regards HDR10+ as unnecessary
  • By Andy Bassett
  • Published
