Quantcast
Denon X2300w, ARC and a new 2019 LG C9 Oled
rousetafarian
HDMI cable out from HDMI 2 (Arc) on the new LG OLED TV to the HDMI out on the AVR (the only cable linking the AVR to the TV) and there is no audio from the WebOS Apps via my external speakers.
Other external sources into the AVR HDMI 1 and 2, namely Sky and PS4 work fine, just the apps on the TV.
Any thoughts, it’s driving me mad as I’d like to use the native apps on the Tv, Netflix, Amazon, You Tube etc
Please advise
Regards
rousetafarian
CEC turned on, on the TV and amp? -Eliminating all of the usual things.
All double checked....Simplink on the LG and HDMI control CEC on the amp all ticked
Rambles
HDMI cable is the next thing to try, a premium certified one.
rousetafarian
mushii
Denon ARC can be very temperamental. My 3400 is a nightmare, my 2400 is flawless. If we have a power cut my 3400 has the same problem that you have. I have to power off TV and AVR at the wall and disconnect the HDMI. Leave everything off for 5 Minutes. Power on both with HDMI disconnected. Put both into standby, connect the HDMI lead and 90% of the time audio comes back. If it doesn’t rinse and repeat.
rousetafarian
Good to know, I’ll try this later, many thanks
gibbsy
You're being very kind there. I were certainly preface that reply with a good old Anglo-Saxon word. I've given up long ago and reverted to optical.
rousetafarian
So an optical cable from the TV to my amp would achieve the same results as ARC over HDM?
gibbsy
Optical can only pass Dolby Digital 5.1. ARC, from your LG is capable of Dolby Digital Plus and it's associated Atmos metadata if present. ARC is therefore better, but so problematic especially with the older Denon models such as yours and my 6200. It's not such a big loss for me as my Panny OLED is not Atmos capable.
To improve your connection a new receiver that is eARC capable would be better as I also believe the LG has that ability.
rousetafarian
I’d be happy with DD 5.1 tbh, the AVR is only a couple of years old so I’m hesitant to upgrade currently, despite the the brand new LG being eARC
Epistemon
I suspect your TV main PCB. Had my OLED55B8 main board replaced to fix broken ARC. See my post here:
Similar threads
