Quantcast
DENON X3500H and outputs ZONE 2, PRE OUT
dante01
Deal with the Bass Management prior to running the calibration and not before it. THe AV receiver will simply erase those settings and ignore them if you run the calibration.
This should have been done prior to running the AV receiver's calibration process. You need to do things in this order:
  1. Configure the sub's own settings
  2. Run the AV receiver's calibration process
  3. Deal with and configure the AV receiver's bass management
As to the sub's own cnfiguration. Set it volume dial to about one third, set phase to 0° and set the frequency dial as high as it allows or to a dedicated LFE setting option if there is one. AS said, these settings all need to be done prior to running the calibration and should not be altered aftward unless you intend to rerun the calibration again.
After tha calibration, set all speakers as being SMALL and set all crossover as being 80Hz.
I'd suggest you leave Dynamic EQ off and set the subwoofer setting to just LFE and not LFE + MAIN.
senzaparole
thank you very much Dante!
1. During the calibration do I have to rotate (when audyssey asks me) the gain knob of the subwoofer to make sure that at the end of the calibration the subwoofer level is 0db or at most + 3db?
2. Last question: should I use the two sponges I found in the two holes of the subwoofer?
dante01
The subwoofer's gain should be set at a level that results in the calibration setting it's level within the adjustable range. The closer you can get this to 0db then the better, but it doesn;t have to be exactly 0db.
The ports on the sub help it attain the lower frequencies, but can also result in noise associated with air flowing out of those ports. I'd try to leave the biungs out if possible.
aweiss01
Apologies if this has been asked before, but I just set up my AVR-X3500 and am trying to get Zone 2 to work. My set up is 5.1 in the main zone with amp assigned to Zone 2 for a set of 2-channel stereo speakers in another room using the remaining 2 surround back speakers. In addition, I have an amp plugged into Zone 2 pre-amp out using the component jacks for 2 additional 2-channel stereo rooms.
Using my cable box plugged into the HDMI, I am trying to get audio only to zone 2 while maintaining 5.1 sound in zone 1. The only way I’ve found to do this is to switch all speakers to PCM which changes the main zone to stereo only. Is there something I’m missing? Is this not possible with the AVR?
Thanks in advance.
dante01
If wanting to portray the same source in both the main and the second zone then you'd have to limit the audio to just 2 channels. The AV receiver doesn't include independant audio conversion for the second zone, but has to convert it or mix it down to be able to portray it in the second audio zone.
2-channel PCM signals are output from a device connected to the input source selected for ZONE2 and can be played back in ZONE2.
If you want to play back HDMI sources that wouldn't otherwise be encoded as 2 channel PCM in ZONE2 then you'd have to set “HDMI Audio” to “PCM”.
In such instances, the MAIN ZONE audio will also be converted to 2-channel PCM signals if the MAIN ZONE and ZONE2 are set to the same input source.
senzaparole
Thanks Dante, in fact I remembered that XTZ wrote to me:
""""If it has set it to negative value, ie. -6 dB or similar, the signal to the subwoofer is probably too weak to trigger it. Then you can lower the gain on the bit subwoofer, run the calibration again. Repeat lowering the gain until the value for the subwoofer output level is 0 dB or even up to +3 dB. This way, the receiver will be able to react.
Coming to the subwoofer is just a multiplier for the signal coming in. I know if you have lower gain on the subwoofer, but stronger signal from the subwoofer. I know you don't lose any power by lowering the gain, as long as you adjust the low level signal coming from the receiver."""
Do you agree Dante?
P.S.
what does biungs mean? sponge?
Not feeling any particular noise, so would you advise me not to use either of the sponges?
dante01
Do you agree Dante?
P.S.
Yes, that would be conducive with what you'd experience.
Yes, the bungs are the sponge cylinders you were supplied to "bung" the ports on the sub with.
either that or they could be SpongeBob SqurePants's upper legs?
senzaparole
Is it mandatory to use the paper support or a tripod for the XT32 Audyssey microphone? Can the microphone be placed directly on the sofa at ear height?
dante01
It would be recommended that you use a mic stand of some description as opposed to placing the mic on soft firnishingg. Besides which, the mic need to be at your seated head height while the calibration is in progress and placing it on the seat of a sofa isn't your seated head heigh or is it?
Use a stand as oposed to not using one. You'll get more accurate results by utilising a stand than you'll get without using one.
senzaparole
above the headrest of the sofa I placed a small cardboard box. I placed the microphone on top of the cardboard box. The tip of the microphone is therefore at the height of my ear.
I read a guide on calibration. to avoid clipping problems it is advisable to slightly increase the gain of the subwoofer during calibration so as to obtain at the end of the calibration the level of the subwoofer equal to at least -6db.
There should be no problem switching on the subwoofer if the power is set to ALWAYS ON. What do you think about Dante?
dante01
There should be no reason the increase the gain during calibration. The AV receiver would simply make adjustments accordingly.
I'd suggest leaving a sub set to being always on as opposed to engaging an auto power mode.
gibbsy
Get one of these, well worth the cost as you can position to calibration mic perfectly.
senzaparole
thanks for the advice. I can't find that object on amazon.it. Could this support be the same?
support microphone
support microphone
gibbsy
support microphone
It looks similar but doesn't seem to have the clamp to hold the mic on end of the boom. Search again, I'm pretty sure one with a clamp will be on there somewhere. Of course you could get that and tape the mic to the end of the boom.
senzaparole
I'm redoing the calibration.
I set the gain of the diver at 12 o'clock before starting the calibration.
During the calibration Audyssey asks me to lower the gain of the subwoofer up to around 75 db. I turned the sub gain knob until I saw about 70 db on the TV screen.
I continued the calibration.
At the end of the calibration I noticed that the level of the sub is 0db.
All correct?
P.S. If in a specific situation I wanted to hear stronger basses I can manually change the level of the sub to + 2db (without obviously doing the calibration)
senzaparole
ok thank you!
If in a specific situation I wanted to hear louder basses, can I manually change the level of the sub by setting + 2db? (without obviously doing the calibration)
dante01
If wanting to make adustments in accordance with your own personal preferences then it would be suggested not to do this by either altering the gain/vomume on the sub or muy changing the subwoofer speaker level in the main speaker configurations.
There are tone adjusts in the OPTIONS menu and there is a BASS setting there that can be used to adjust the bass by -6 dB to +6 dB. “Tone” settings are stored individually for each input source. The tone adjustments are not in effect in the receiver is set to its PURE DIRECT mode though and wouldn't be applied if DYNAMIC EQ is set to ON.
THere's also a CHANNEL ADJUST setting within the OPTION menu that allows you to make adjustent to the levels independantly of the main level configurations.
I'd suggest you use this to make any adjustments to the levels because it is then much easier to revert to where the receiver calibrated itself. Again, this setting stores these level settings individually for each input source.
senzaparole
thanks dante!
I tried both options and I find it more convenient to use CHANNEL ADJUST because it also allows me to increase the db of the center speaker as well as the db of the subwoofer.
Trending threads
Latest News
AVForums Podcast: 27th January 2020
  • By Phil Hinton
  • Published
Raidho TD Series loudspeakers arrive in UK
  • By Andy Bassett
  • Published
Nokia 2.3 phone available in UK for £100
  • By Andy Bassett
  • Published
Sky to launch Documentary and Nature channels
  • By Andy Bassett
  • Published
StormAudio to launch MK2 home cinema range at ISE 2020
  • By Andy Bassett
  • Published
