I have no idea what you're talking about. All this new fangled 21st century stuff goes over my aging head. Here's a page from the manual.
Playing back a file saved on a PC or NAS
This unit is compatible with MP3 ID3-Tag (Ver. 2) standard.
This unit can show the artwork that was embedded by using MP3 ID3-Tag Ver. 2.3 or 2.4.
This unit is compatible with WMA META tags.
If the image size (pixels) of an album artwork exceeds 500 × 500 (WMA/MP3/WAV/FLAC/Apple Lossless/DSD) or 349 × 349 (MPEG-4 AAC), then music may not be played back properly.
A server or server software compatible with distribution in the corresponding formats is required to play music files via a network.
For playing mentioned audio formats via a network a server software, for example Twonky Media Server or jRiver Media Server, needs to be installed on your computer or NAS for full support. There are other server software available too. Please check supported formats.
Specifications of supported files
| Sampling frequency | Channel | Bit rate | Extension |
WMA∗1 | 32/44.1/48 kHz | 2-channel | 48 – 192 kbps | .wma |
MP3 | 32/44.1/48 kHz | 2-channel | 32 – 320 kbps | .mp3 |
WAV | 32/44.1/48/88.2/
96/176.4/192 kHz | 2-channel | – | .wav |
MPEG-4 AAC∗1 | 32/44.1/48 kHz | 2-channel | 48 - 320 kbps | .aac/.m4a |
FLAC | 44.1/48/88.2/
96/176.4/192 kHz | 2-channel | – | .flac |
Apple Lossless∗2 | 44.1/48/88.2/
96/176.4/192 kHz | 2-channel | – | .m4a |
DSD | 2.8/5.6 MHz | 2-channel | – | .dsf/.dff |
Only files that are not protected by copyright can be played on this unit.
Content downloaded from pay sites on the Internet are copyright protected. Also, files encoded in WMA format when ripped from a CD, etc. on a computer may be copyright protected, depending on the computer’s settings.
The Apple Lossless Audio Codec (ALAC) decoder is distributed under the Apache License, Version 2.0 (
http://www.apache.org/licenses/LICENSE-2.0).
back to top
INTEGRATED NETWORK AV RECEIVER
Copyright © 2018 D&M Hol
