DonJorginho
Established Member
Hi all, I am currently stuck between two TVs from Tesco to serve as a cheap and big screen for gaming and cinema.
The two models are a Sharp 40AJ6KE 40 inch Smart 4K UHD TV (£219) and a Toshiba 40L2863DB 40 inch FHD Smart TV (£220)
Sharp Manual: http://www.umc-uk.co.uk/instruction-manuals/Sharp/Universal Manuals/SHA-MAN-0395 NEW CHIPSET v10_web.pdf
Sharp Specifications: http://www.umc-uk.co.uk/instruction...4T-40AJ6KE1FB/SHA-QSW-0120_40AJ6KE_v3_web.pdf
Toshiba User Manual: https://toshiba-tv.com/pdf/84ec8b384d88a7945718750b53caccee/35/40l2863db.pdf
The Sharp is an UMC offbrand and the Toshiba is a Vestel offbrand.
Which one would you suggest is better for my needs, as am looking for something to last me at least 2 years so am thinking of the PS5 which will run at 4K 60fps as the industry norm so keep that in mind!
Am looking to buy one tomorrow so any help ASAP would be much appreciated!
