Dynaudio Xeo 20 vs. Elac Navis ARB-51 vs KEF LS50 Wireless
Spooky Electric
As things stand, I’ve narrowed my choice of new bookshelf speakers to the three options in the thread title.
I would therefore, be keen to hear peoples’ thoughts and experiences with any, or all of the above.
Similarly, if anyone recommends an alternate option in the same price bracket, please share.
Look forward to hearing opinions!
sathtom
Navis ARB-51 is the best choice if you want your speaker to scale well with High-end Preamp/DAC's. KEF LS50W is preferred if you want an All-in-one Solution and don't want to add High-end Seperates in future. Also, Navis ARB-51 is a good choice if you want to integrate it with HT as front Channels. Subwoofer integration is also relatively easier as it has crossover switch with three options (Flat, 60Hz & 80Hz).
Spooky Electric
Thanks for the summary.
How do the Navis’s sound unpaired with a Preamp/DAC versus the Kef’s?
I am hoping to do a listening test sooner rather than later, but would be good to get others’ thoughts in the meantime.
sathtom
KEF LS50W is a combo of Speaker/Power-Amp/Pre-amp/DAC/ADC/Streamer. LS50W is the best choice for HiFi Minimalist who don't want to add seperates like Preamp/DAC in future. Even if you connect a High-end DAC to LS50W, you will hear a improved Sound Quality for sure but will never reach that High-end DAC's potential because once the Analog signal reaches to LS50W it will convert into digital signal, does the DSP processing and then again converts it into analog using LS50W inbulit DAC. So, LS50W inbuilt DAC is the Limiting factor we need to live with.
On the other hand, Navis is a combo of just Speaker/Power-Amp. Thats all. To make Navis to work, we need "Preamp & DAC" or atleast a DAC with voume control. Connecting a Preamp/DAC/Streamer combo like "Bluesound Node-2i" or "Cambridge Audo CXN V2" with Navis will give a better sound quality than LS50W.
LS50W ==> Very Clean & Crisp. Bright sounding.
Navis ARB-51 ==> Slightly Rolled-off Highs, Warm sounding. non-fatiguing.
Please listen to the speakers and then take a decision.
Similar threads
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
