pc99
Established Member
Hi Guye.
I have an Epson EH-TW3200 projector which is now around 9 years old. It's working perfectly except for an issue with the fan. I think maybe the bearings on the fan are finally going as it makes an annoying rattle which is quite noticeable.
Can't fine any kind of service manual for it, just wondering if anyone has ever tried to replace the fan.
I'm reasonably technical (I used to clean the LCD panels of previous projectors back in the days when dust blobs were an issue).
So any advice greatly appreciated.
I don't really want to dump the projector just yet, until I can get a True 4K replacement with lens shift.
But if I can't fix the noise, I'll have to consider a replacement.
Thanks in advance.
Thanks in advance.
