Going to wall mount some bookshelf speakers, can someone give a bit of guidance on the best positioning ?
I know rears should be at ear level or preferably just above, does this apply to the front ones too ? Or should I mount them somewhere in the 600-800mm range (typically the height of stands)?
Also, is it better to mount the fronts closer together (say 1.8m) apart and direct them straight or wider apart (say 2.5m) and angle them in a little ?
Thanks.
Thanks.
