are you friends with everyone else ?
A few yes.
@LeftyXXIII what's the prize money like?
is anyone having any problems with the rear view mirror flickering?
Quick look through KudosPrime and you seem to be No.2 on the Veyron leaderboard, at the moment with your 51.804....What are the actual times then as I'm 3rd on the leader board but the 2 above me are not on the veyron?
I’ve heard the Nacon Revolution is good, but never owned one myself, but then I’ve never broken one the standard controllers.Looks like I may be out of this until I get yet another pad, is there any more robust pads out there than the standard controller?
I've got 3 PS4 controllers and the only issue I had was a broken trigger hinge, which was easy enough to fix and was after several years of use.
Is it the analogue stick that's broken?
Got a link to that please? I've looked on kudos prime but can't see the leaderboards for it.Quick look through KudosPrime and you seem to be No.2 on the Veyron leaderboard, at the moment with your 51.804....
Suzuka Circuit East Course | 2020-02-27 | Leaderboard | Gran Turismo Sport | kudosprime.comGot a link to that please? I've looked on kudos prime but can't see the leaderboards for it.
Thanks, how do you single out the veyron times?
Don’t think you can do that..Thanks, how do you single out the veyron times?
Ah OK I thought you could, how do I know I'm the 2nd fastest in a veyron at the minute then?Don’t think you can do that..
Just by scrolling through the pages and recognising the player names by country...Ah OK I thought you could, how do I know I'm the 2nd fastest in a veyron at the minute then?
