Habanero
- Joined
- May 23, 2006
- Messages
- 1,876
- Reaction score
- 1,210
- Points
- 511
I’ve got four DS4s and usually use the same one all the time.I’ll be plodding on with my g29 for a long time
It’s a great wheel though, I really like my G29 and first a kind of budget wheel it has pretty decent pedals.
I am looking forward to a step up in FFB though as that is where it really lacks I think.
and the rattling
Rattling? Not had that. Might get a little grinding of the gears but sounds like your FFB is maybe set too high.
possibly , I’ve found out something weird , if it’s plugged in from cold then you get wheel resistance and ffb , if you start from standby you get wheel resistance but no ffb , does that make any sense how I’ve described it ?
Can anyone help and not sure where to post
Has anyone an idea of the shipping weight of the t300rs and pedals in there standard box.
Loljust had a google and it looks as though about 9kg ......
Lol
Just spent a good half hour solid and couldn’t find it cheers
Having some epic races around Bathurst tonight. All super clean, and hard racing. Won one, and have had a 2nd and 3rd too! Just started 10th despite the decent qualy time, and finished 5th! Happy with that! The Gr3 Subaru isn't the fastest in a straight line, but a cracking car to drive!
so have I , the racing has been generally very fair , it’s almost as if someone has flicked a switch ....
I have a 99 safety rating, so only get put in with clean racers. Raced some seriously quick guys tonight, and my consistency beat a lot of them!
doesn’t seem to work like that with me , my SR is topped out and yet I still get the dickheads
I've never done a GT-Sport race that involves pit stops, but quite fancy a go in the weekly race around Suzuka. Are the pit stops easy to do? Is it automatic or can you set the strategy beforehand?
You just go in when you feel like it. Usually there’s strategy like no stop and fuel saving. Might need a few races to see what works or checkout done YT videos of strategy for the weeks races. Choice of tyres can mix it up quite nicely too.
They can awesome races or they can be horrible racing on ice as your tyres die in a no stop race.
