Bertyboo
I have a pioneer A300 amp and ive bought a graphic equalizer to connect to it but there are no output sockets on rear of amp just input sockets how do i connect equalizer to amp and amp to equalizer thanks guys
Ive put a pic of amp on these are ports i have i also have a cambridge a1 mk1 ampBefore everyone tells you what a bad idea graphic equalisers are, you can use the tape loop function. Plug the graphic equaliser into the tape sockets and press the tape monitor button. This will route the audio to the tape output and then you will hear the processed sound coming back in when the monitor button is pressed.
