sohe68
Established Member
I have an amp that I would like to be able to power toggle in a couple of activities with a Harmony Elite/Hub. The AMP lacks an "IR eye" but uses a mini mono jack IR input and I have the codes from the manufacturer. The amp also has a DC trigger input but my DAC/Preamp lacks the desired output, hence the IR input is my only option apart from manual toggle.
Is it possible to just attach a 2.5mm to 3.5mm (1/8") cable from the Harmony Hub to the amp, or do I need some sort of wired IR receiver in-between to translate the IR from the Hub into "electrical signal" to the amp?
Grateful for any input, thanks!
