ZetecShearer87
Established Member
I am torn between two laptops bother acer nitro 5’s
similar in price, one is intel and the other is amd ryzen
I prefer the ryzen as it’s the 4600u but the intel one has a slightly better gpu. I have read the new amd chips wipe the floor with intel.
Can I have some help on which is better or should I go for something else.
I only have a 1000 budget to spend and no more
thanks
thanks
