SPECS
AUDIO
Amplifier Output Details
110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.09% - 7 channels (surround)
120 Watt - 8 Ohm - at 1 kHz - THD 0.9% - 7 channels (surround)
AUDIO SYSTEM
Type
AV network receiver
Subcategory
AV components
Functions
AV network receiver, digital player
3D Technology
Yes
Media Content Source
Network, USB-host
Audio Formats
AAC, FLAC, MP3, WAV, WMA
Sound Output Mode
Surround Sound
Audio D/A Converter
24bit / 192kHz
Built-in Decoders
DTS 96/24, DTS Neo:6, DTS decoder, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS-HD High Resolution, DTS-HD Master Audio, Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Pro Logic II, Dolby Pro Logic IIx, Dolby TrueHD
Surround Sound Effects
CINEMA DSP 3D, SILENT CINEMA DSP, Virtual CINEMA DSP, Virtual Presence Speaker
Sound Effects
Extra Bass
Surround System Class
7.2 channel
Digital Sound Processor (DSP)
Yes
DSP Preset Qty
17
Additional Features
Apple AirPlay support, Audio Return Channel (ARC), Bi-Amplifying, Deep Color, MHL (Mobile High-Definition Link) support, YPAO multi-point measurement, YPAO with R.S.C. (Reflected Sound Control), Yamaha Parametric Room Acoustic Optimizer (YPAO), auto power off, compressed music enhancer, dual-zone capability, iPod/iPhone/iPad ready, smartphone remote controlled, source direct, x.v.Color
Bass Control
Yes
Treble Control
Yes
HEADER
Brand
Yamaha
Product Line
Yamaha AVENTAGE
Model
RX-A1030
Packaged Quantity
BUILT-IN DISPLAY
Type
fluorescent
MISCELLANEOUS
Color
black
Color Category
black
AMPLIFIER
Input Impedance
47 Ohm
Input Sensitivity
200 mV
AMPLIFIER OUTPUT DETAILS
Output Power / Channel
110 Watt, 120 Watt
Output Impedance / Channel
8 Ohm
Frequency Response
20 - 20000 Hz, at 1 kHz
Total Harmonic Distortion (THD)
0.09 %, 0.9 %
Channel Type
surround
Channel Qty
7
RADIO
Tuner Type
digital
Tuner Bands
AM/FM
NETWORK & INTERNET MULTIMEDIA
Functionality
Internet radio playback, digital audio playback
Internet Streaming Services
vTuner
DLNA
Yes
AUDIO SPECIFICATIONS
Type
Amplifier
Frequency Response
10 - 100000 Hz
Signal-To-Noise Ratio
100 dB
0.04%
POWER
Power Consumption Stand by / Sleep
0.35 Watt
SIGNAL PROCESSING FEATURES
HDMI Switching
Yes
HDMI Pass-Through
up to 4K
Video Conversion/Scaling
HDMI to HDMI scaling, analog to HDMI up conversion
Upscaling via HDMI
up to 4K
CONNECTIONS
Qty
1, 2, 3, 4, 7, 9
Type
7.1 channel audio line-in, 7.2 channel audio line-out, DC power output, HDMI input, HDMI output, LAN, S-Video input, S-Video output, SPDIF input, SPDIF output, USB, audio line-in, audio line-out (multi zone), component video input, component video output, composite video/audio input, composite video/audio output, headphones, monitor output, phono input, remote control, serial, speakers output, trigger
Connector Type
19 pin HDMI Type A, 4 pin USB Type A, 4 pin mini-DIN, 9 pin D-Sub, RCA, RCA x 2, RCA x 3, RCA x 8, RCA x 9, RJ-45, TOSLINK, banana/spade x 2, phone stereo 6.3 mm
Connector Location
front, rear
DIMENSIONS & WEIGHT
Depth
17 in
Width
17.1 in
Height
7.2 in
Weight
33.29 lbs
Upscaling via HDMI
Up to 4K
HDMI Pass-Through
Up to 4K
HDMI Switching
Yes
Analog to HDMI up conversion, HDMI to HDMI scaling
GENERAL
Manufacturer
If you're happy with the Yamaha then is there really any need to change unless you want the new options that the Marantz can bring. The Advantage range are very good. I'm not sure the HDMI level, if 1.4 then you may get HDCP issues with 4K video and of course you won't have Atmos. The HDCP is not so much a problem as you can connect the player directly to the TV and just pass the audio to the Yamaha.
