whiteswan
I have a Hisense 65B7100 4k Tv. K0420 Firmware (I updated to 0424 firmware and it still does this). Netflix with a 4K Subscription.
If I open NETFLIX via the shortcut key on the tv remote control - I can see that certain titles are labelled "4K" - The Woods for example......they open and play fine but the picture is NOT 4k - indeed if I press Menu / Settings / Support / System Info this gives data on the current source displayed and it confirms that it is 1080p - it NEVER gets to 4k resolution - even if left for 10 mins - I have tried both wired and wireless - makes no difference - broadband is 350 meg dl and 35 meg upload and always get max speed in tests etc.
I also have a Beefy PC Connected to the tv via HDMI - doing the same test as above clearly shows 4k resolution on 4k media files/games.
And my ROKU ULTRA - again connected via HDMI displays the exact same programmes labelled 4k on Netflix as 4k - Picture is vastly superior than using the built in app.
So what is going wrong ?
I would have thought that using the built in app would always give the best possible picture - so what is happening ?
The built in Youtube app displays 4k just fine.
Can somebody else pls try the above and see what resolution image you are getting from the built in app.
Dave
Dave
