kgg
Hi. Does anyone know if it’s possible to install Hive heating control in a flat with a communal boiler? There is currently a timer/controller for heating and water, a hot water tank with thermostat, two motorised valves, a pump and a room thermostat.
Hot water is supplied to the flat and returns back to the communal boiler.
I don’t understand how the pump is controlled.
I have Hive in my house and the Hive receiver simply has connections for water on/off and heating on/off.
Can’t get a definitive answer from Hive support.
Thanks.
Thanks.
