This is the Easy/Fast/Cheap/Safe Method to remove the red tint and lower the elvevated blacklevls that most 9G Kuros suffer from today.
What you need:
9G Kuro with red tint and elevated blacklevels
Harmony Remote
(Tanks to "Inferno" for posting the code)
Hex/Pronto code for SM access
(one long line)
0000 0068 0000 0022 0168 00b4 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0043 0016 0043 0016 0043 0016 0043 0016 0016 0016 0043 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0043 0016 0016 0016 0043 0016 03dd
ASketh Logitech Harmony Cust Serve to add it to your Harmony remote by Emailing them.
When you have got access to the Service Menu with your Harmony Remote you will use your regular TV Remote to navigate in the Service Menu.
Follow These Steps to get your Kuro back to were it was when it was new with Deep Blacks without Red Tint:
Press the "mute" button twice until it says Panel Factory +
press "enter"
now press the Down Arrow on the remote 4 times
Now it says Panel -1 ADJ (+)
Press Enter here
Now your in
Press the down arrow on the remote 8 times and you get to a voltage named
VOL YKNOFSA D 128
Use the left arrow on the remote and lower it from 128 to 90 (80 for sets with over 10k hours)
when done hold enter to back out of panel -1 ADJ
then close the menu and enjoy your new kuro.
you will see the changes right away no need to power it off
What you need:
Harmony Remote
(one long line)
press "enter"
Press Enter here
Now your in
VOL YKNOFSA D 128
