How well do 4k tv's display 1080p signals ?
martkt10
Hi, Thank you for looking at this question,
I have read online that a 1080p can look fuzzy on a 4k tv, is this true for all 4k tv's
The reason i ask is that i would like to use a 43'' tv as a monitor so that the text is larger (problems with eyesight)
and the computer i currently have can only do 1080p.
I know that oled are very good, but being disabled i cannot afford an oled tv
Thanks again for any advice given
MaryWhitehouse
1080p on 4k should look great :) Also at 43” is our get no benefit of 4K.
noiseboy72
Never noticed any fuzziness on my 48" 4K TV. The scaling is very good and even standard definition is quite watcheable from a couple of metres away.
groen
The LG nano cell use an IPS panel so have great finer detail for a lower price than OLED. The Sony 900h is good choice for gaming with full array led back light and hdmi 2.1.
If you must buy a TV instead of a computer monitor then I recommend the 49NANO816NA. Then I would set the resolution to 4k but increase the windows scaling to 150% or more and if you have a modern AMD graphics card you can do what is called GPU scaling.
Most 4k TV will look ok at 1080p resolution just have to make sure you set the right refresh rate and if you want that clarity go with IPS panel for a PC monitor.
martkt10
I'm using a mac and they don't have that kind of feature , but thank you for the recommendation
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
