markb1980
BESTÅ grey, Supporting leg, 10 cm - IKEA
BESTÅ grey, Supporting leg, 10 cm. The supporting leg gives stability to the BESTÅ combination without being visible from the front.www.ikea.com
if you were going to have it that close to the floor where the middle supports are going to touch the floor to support it then probably no need to wall mount it in the first place? If it’s going to be wall mounted it would need to obviously be secured to something strong behind the wall as the unit is pretty heavy in itself.
