So finally got some doors for my Besta unit, was waiting on oak coloured but they've been out of stock for months so went with black.
It depends how big the overhang is. My Denon was just overhanging so I adapted the back plate of Besta for its connections to fit through.I have a Besta unit but unfortunately my AVR hangs over the back and will be impossible to meet flush with the wall. What have others used instead?
Yup that is a lot. Big old amp thenIt's a case of back panel removed from the unit and overhanging by a good 7cm. Definitely can't be adapted.
I went for the 64cm high one , really happy with it for £200View attachment 1207032View attachment 1207033
I had an XPA-3 (3 chan) in the Besta unit without issues but i did have ti pull it further away from the wall lol.
Am now downsizing so trying to find someone who wants the big besta unit.
I’m just out and about at the moment. But drop me a PM. I can take any measurements and pictures you like. Still want to get rid of mine as one section is totally empty.Hiya mate, hope you're well. I'm now myself looking into the Besta Units, 180x42x38. The depth at 42" what was it like with the Emotiva? How far away from the wall, I find its the mains cable thats a pain. Also does anybody know the internal dimensions of the Besta units? For the 38mm height version. I have a lot of equipment to fit in . I really want to get my centre speaker out the current unit and sit it on top.
BESTÅ TV bench with doors, white/Selsviken high-gloss/white, 180x42x38 cm - IKEA
BESTÅ TV bench with doors, white/Selsviken high-gloss/white, 180x42x38 cm It’s not only the TV that’s smart! BESTÅ TV benches combine contemporary good looks with practical function. You get lots of storage space and relief from cables that tend to get messy and gather dust.www.ikea.com
i do for now but when i get the smaller unit ill be putting it back on topI'm after white mate not black, what are you planning on replacing it with? So you still have your centre on top or inside the unit?
We have a load of the light grey doors, they look great imo, just the shade of grey you would want from light grey.
Sure, it’s not a tv cabinet but I’ll take a pick of the units when I get back from work. There is a dark grey glossy door, we have some of that too but not assembled yet. It’s got more finger prints on the door I picked up to look at than the Matt grey ones have had in over 2 years.
i just replaced my smaller Besta cabinet with a bigger one, and stuck a 55" TV on it too (previous was 43").
this was my previous setup
Thanks mateynot sure which ones they were, they came with the cabinet type i ordered.
it was this specific one, so you might be able to see what shelves it is
Products - Discover Our Full Range Of Furniture And Homeware
Browse our full range of products from dressing tables to complete modern kitchens. Click here to find the right IKEA product for you. Shop online and in store today.www.ikea.com
edit - the package details says
BESTÅ Glass shelf
Article no.:602.955.32
Width: 36 cm
Height: 1 cm
Length: 58 cm
Weight: 2.52 kg
Package(s): 4
