martin once you have done your best let it go and enjoy the stunning imagesNo harm in trying to get the best out of the basic controls Tim .
are you happy that the N7 overall was worth your investment?
Since the timing is about right, could the power injector have screwed the PJ somehow? Why would it affect the black floor and not the HDMI ports?
Thank you, I had noted some of those comments. Hmm, to contact JVC next then and see what they say I guess.It's quite possible, AVSforum owners thread has a couple of recent, some older, cases of HDMI board damage from HDMI over voltage caused by cables. JVC took care of those cases under warranty....
That's a good shout, will try tonight when it's dark. Unfortunately, that's what Arcam said to do.. now regretting. The original issue seems to have been something else.@Harry1983 Might be wise to change the HDMI cable just in case it's over-volting the connector and repeats the issue on the repaired unit. I've used several of these cables with my x9500 and currently use an AVR850 with it. No power injector needed.
Amazon product ASIN B07L2Y52LW
I'm sure others have their own recommendations, this one just works solidly for me.
Cheers! Yes, but the Arcam has had it's own issues with locking up, it was suggested at the time.i use a ruipro 10m cable direct to my arcam avr 390 with no power injector whatever that is - i thought the whole point of fibre optic hdmi was that you could have much longer than 10m runs with no signal loss
isnt your dealer the first point of call warranty issues?
good luck
So have you tried turning the Iris to manual, does this stabilise things?To add, I've connected the sources directly and made the chain as simple as possible, checked all settings, nothing seems to bring the black floor back.
I did, it does mitigate it when the value is reduced (-10 and lower) at the expense of brightness, shouldn't really be like that.So have you tried turning the Iris to manual, does this stabilise things?
did they say what 3.11 does over 3.10?
Just got the new firmware, will test once the sun goes down.
Yes, that's precisely what I'm hoping for, let's see.. JVC wanted me to check the iris as one of the first things after the update. If not, I will have to run a factory reset from the engineers menu as a last ditch before shipping back.I’m guessing that if the black floor is stable and in no way inconsistent on a manual setting, you could assume the dynamic Iris is getting confused. Hopefully a firmware update will reset whatever drives the dynamic Iris.
finally got round to running an autocal again today (after ~1000hrs), had no visible reason to other than it's been a while and I needn't have bothered as it had barely drifted in SDR and just lost a bit of output in DCI-P3 (but still measured pretty linearly vs target)
SpyderX and i1pro (with an i1d3 for verification)Which meter are you using?
